4.0L OHV Starter Issue 1993 XLT SC 4.0 Auto
Angry Possum
No Fat Chicks, Truck Will Scrape
💻 TRS Socials
Law Enforcement
Old Bridge
NJ - USA
Other
2005 Jeep TJ
Vehicle
Drive
N/A
N/A
31's
Sometimes you eat the bear, sometimes the bear eats you.
1993 Ranger 4.0 XLT Auto
Prior to having this starter issue dilemma I sprayed a little WD40 on the battery terminals, just after waxing the ranger yesterday, and cleaned the rims. This is very odd. I highly doubt this was the issue.
My starter was replaced last year or maybe even less than a year ago. When I attempt to start it the starter has a clunk/thump sound. I cleaned the battery posts, also the battery load while attempting to start it and it's fine, it doesn't go past 12.2 volts when attempting to start. The voltage is 12.8 volts when not under load, so the battery seems fine.
I'd like to jump the solenoid out but it won't jump out using a screwdriver along both terminals. How do I go about checking the solenoid first before I do anything else as this is my priority currently. Can I use a multimeter, if so how do I check it.
Also if the ground is bad to the starter, is there a way I can ground it without going underneath directly to the starter.
Is there anything I can troubleshoot also to see if the starter is defective. I'll attempt to tap the starter with a hammer while my girlfriend trys to start it later when she gets home from work. It boggles my mind why all of a sudden the starter crapped out.
Thanks
Use a single jumper cable, one end clamped on battery Negative, the other end clamped to the engine block. And check that the starter mounting bolts are still tight.
Are you talking about the solenoid, which is mounted on the starter motor? Or the starter relay, which is usually mounted on the inner fender, up near the top of the engine bay?
The solenoid which is on the inner fender.
Thanks, I'll try that next, if she starts do I have a bad ground on the starter?
Could the battery be bad if I'm getting decent voltage when attempting to start it. It only drops down to 12.2 volts. I did have the engine off and radio on when I was waxing the truck, but every 10 minutes I would start it. And it had no issues starting.
If it consistently starts with a temporary jumper cable ground, and not without it, that would indicate that the battery Negative cable has failed.
The 12.2 volts part is good, but amps is what the starter motor needs. Poor or failed "conductors", i.e. a bad cable, is what robs you of amps.
FWIW, my battery is a lil over 5 years old. However, I have another one I can swap out, after I try out the other troubleshooting ideas.
To check the starter relay - the device mounted on the inner fender.
First make sure full battery voltage is present on the big terminal where the battery cable is attached.
Second, take a jumper or screwdruver and connect from that terminal to the small terminal. This simulates the signal coming from the key switch. If the relay is working, you should hear a strong "click" or "clunk" as the relay closes its contacts. The starter motor should also spin and try to start the motor. If it does not, you can try it again and measure the voltage on the other big terminal that sends power to the starter motor. If it is full battery voltage, then the starter relay is good. If it is significantly less than battery voltage, the relay is probably bad.
One more test. Short directly across the big terminals. The starter motor should turn. If it doesn't, then there is a problem with the starter or the ground path back to the negative battery terminal.
Sorry to be stubborn about terminology concerning starter relay and solenoid. These are very different components with different jobs. Especially when looking at the wiring diagrams or communicating with others, it gets confusing when the wrong terminology is used. The solenoid is mounted to the starter motor. It usually looks like a big lump attached to the side of the starter. It does 2 things. 1 - it shoots the bendix gear forward to engage the teeth of the flywheel. 2 - it closes an electrical contact sending power to the motor windings. The starter relay, up on the inner fender is just an electrically operated switch that sends power to the starter solenoid when the ignition switch is activated.
I just came back in. I replaced the battery with a much newer one and it had the same issue. I also ran a seperate ground from the battery to the block, that didn't work. I also tested the solenoid and it was getting voltage. I then tried jumping out the solenoid but it just sparked and the starter didn't engage or clunk.
@Curious Hound , which terminals do I jump out on the solenoid, as there are three.
2 large terminals - one for positive and one for negative, there's also 1 small terminal.
@Curious Hound I successfully jumped the solenoid from the battery to the small post on the solenoid and it clicks. Does this mean the solenoid is working?
There is no "negative" terminal on the starter relay.
The little terminal is 12volts from the ignition switch. This energizes the starter relay coil.
One large terminal is 12volts from the battery.
One large terminal sends 12 volts to the solenoid on the starter when the ignition switch energizes the starter relay coil.
The metal base of the starter relay is the negative sude of the starter relay coil and must have a tight, clean connection to ground /the sheet metal inner fender.
Review my instructions again and study the wiring diagram. If necessary, I'll create a video tomorrow.
Ok thanks 👍 In the meantime I'm going to check all the wires to the starter. I'm gonna have to jack her up to get under there comfortably. I'll advise.
I tapped the starter with a hammer while my friend cranked it. Fired right up with the first tap. I ordered a new AC Delco starter from Rock Auto. Further, The local neighborhood auto parts store where I purchased the starter 9 months ago, won't refund or replace it without a receipt, really who saves the receipt?...I'm done with these mom and pop shops now. They sell garbage chinese parts, just like Amazon, so why pay mom and pop shop prices when u can get the same crap on Amazon, but for way less.
