Updated: stalled on highway, won't start, need FF info
This is a continuation of my 2000 Ranger blues. Its a 2000 3.0 FF 4wd atx, 'bout 72,xxx miles. Couple of weeks ago whilst crusing up towards Ann Arbor it started bucking and stalled out within 2 miles. Did the obligatory wait 15 then crank, wait another 15 and it still wouldn't start. Had it towed to a Ford dealer near my place who diagnosed it as a bad/shorted flex fuel sensor. The sensor is a dealer only part, and lists for about $660. I declined the repair,
paid the diagnostic fee and towed it home. For grins and giggles I replaced the cam sync sensor, no change in symptoms, still chugs then stalls. The metal tab under the sensor only moves a couple thousandths then has a solid click either way, so I don't think the syncro gizmo stripped the pin.
Any way, back to the f'in FF sensor. Rigged up a breakout harness and crawled under the truck with an O'scope today. Measured 12v on the blue/orange wire, ground on the black wire, and a digital output on the green/lite green wire. That digital output was at 5v and had a pulse going down to about 2v every 6ms. The signal was hi for about 5.5ms, then low for .5ms. Hmmm, that's a 10% pulse, and I'm using plain 'ol 87 regular in it. If I were one to make assumptions, I would assume that a 10% pulse may correspond to 10% or less alcohol fuel in the system.
Problem is, another site states 40-60 hertz signal for gas, 60-100 for 30% methanol, and 90-130 for 60% methanol. The 6ms I measured translates to about 166 hertz. And do methanol and ethanol read the same in the sensor???
So, my questions are:
1. is a .5 ms pulse on a 6 ms cycle correct for gas with less than 10% alcohol?
2. where does the dark green / with lite green stripe wire go?
Time to head out and rent a scanner, see what the pcm thinks is wrong.
Perry
installed replicator today, fired right up.
Perry
