Some others things the FPR(Fuel Pressure Regulator) was replaced last year, thinking cold start issue stumble was from that, never fixed issue just let it ride since I wasnt havent any driveability problems on road. When I had the intake plenum off and cleaned it I also took the fuel injectors out and cleaned them and put new gaskets and end seal caps on them and replaced injector harness, but that was 5 years ago. Being I live in Pittsburgh with lots of hills, I was starting to think the MAP was having some issues, it would run fine on level ground but sometimes climbing the hill underload it would act like it would bog down, you could feel as you pushed the gas that dead pan feel, back off the gas and push the gas pedal back down some it would go away, sometimes it would continue, was thinking that the MAP could be sticking. There is a vacuum contol switch with a cap on it with a filter under it, I replaced that 2 years ago after you turned off truck it would sound like it was releasing vacuum(makes some sorta noise) unlike before with the old one I replaced never made a noise, since I fixed the EGR line it makes the noise even more pronounced now after you shut the engine off, I am assuming I have increased the amount of vacuum in the system now. One thing I do not do is scrimp on my Fords, LOL, its like a game. When I bought this truck off some younger dude back in 2002 for 700.00 it had a blown tranny which I rebuilt, also for the longest time the fuel pumps would run continuously until I found out someone did a barn job and bypassed the inertia switch and relay had to retrace wires and got it all hooked back up the way it should be so when you run the codes you can pin point issues accurately. I cant complain about this 26 year old ranger, aftermarket parts as I said before dont last forever. Figure if I come online since im a Ford Fan and like rangers/explorers that I would share my issues im having and hear what others have to say, together we can fix what issues we have with em.
