stage 8 lock nut system
black bart
1993 ranger stx
hi.
busted by the ranger station cop, 4x4 junkie. il try again, sorry did not know. back to my problem. pick up a set of dana 30, 35, 44 stage 8 lock nuts. they don't fit over the warn manual hubs. the tech at stage 8 said they fit but he dose not know the part number. he said he's a chevy guy. im sorry for him. any one with some help. they lock great, no torquing down the outer nut.
thanks for the help with my posting edict, 4x4 junkie look in to this part for your
d 35 and d 44, my dif guy saw them on monday and said he will not use anything else. Yarman Drive Line, Mike Yarman in Lancaster CA. how do i include a pic of my Mazda (MAZDILA) ?
I'm really confused as to what this post is about exactly?
starge 8 locking fasteners
Hi Martin & Sasquatch,
Stage 8 makes hi end locking spindle nuts. they do not require the outer nut to be torqued down to 150 - 200 + lbs to stay on. There held in place with a locking retainer and a grooved spindle nut. A snap ring holds the system in place 1 to 2 deg of the manufacturers specs. Watch the video on three site. Also make bolts for header,s fly wheels, ext. question, is the inside dia. of the warn hub # 29071 the same as warn hub # 37780 ? I'm have clearance problems with the spindle nut locking system.
thanks for any help,
black bart
91' Mazda Navajo, 4.0 almost stock (cal car), 700-4 trans, manual transfer case, 6 in. Superlift, custom tie rods with large hiems, James Duff radius arms and spring buckets, dual shocks, 97' 8.8 rear end with factory disc brakes, Detroit locker rear, d 35 front Auburn e lock, 410 gears, 32 ats and 32 BFG muds, griffin rad, Warn 9000 winch on a portable mount, dual battery, Painless wiring kit.
Yes, dimension wise they are the same hub.
These locknuts will not work with a D35 TTB.
To me its quite easy to just torque the outer nut to 220+ ft lbs....not to mention cheaper than buying some fancy lock nuts.
I've never had a problem with them coming loose.
