Stabilizer bar bushing bolt dimensions?
Paisano
Phoenix, AZ
Hi,
1992 Ranger XLT with 2.9 V6 and 4WD. I'm going to replace my rear stabilizer bar bushings soon. Does anyone know the thread size, length and diameter for both the frame mount
and link-to-link bolts? I did some research but was not able to make a positive determination on the bolt dimensions.
I am going to go get a rear sway bar this weekend so i can hopefully remember tk get the info for you
I finished replacing all the rear stabilizer bar bushings today. I was surprised that I didn't have you use my 'sawzall' or even use MAPP gas flame. The 6 or 7 treatments of PB Blaster and impact wrench loosened the nuts and bolts.
To remove the old bushings, I used a hole saw and power drill. The new bushings pressed in easily by hand. The bolts ended up ending being M12-1.75 X 70mm
