I wanted to post this info here so that it would be easier for someone to find it in the future.
I used an ECHO spring. It worked perfectly on my Dana 35. Others have used the same spring with the same success.
The ECHO spring part # is 69621655730.
Any lawn shop that carries ECHO will be able to get this for you. You can click the link below to find your nearest Echo dealer.
http://www.echo-usa.com/advantage.asp?transaction=search&template=map_search
The cost from an ECHO dealer is about $5 + tax.
It is hard to get over the splines of the axle shaft, but once you do it works great. The boot will fit over the spring. Get yourself 2 hose clamps to hold the boot on once you put it back as you will destroy the factory retainers getting the boot off.
Here are some pictures of my install.
