Spit and sputter at 2k
89PBR96
Pekin IL
I am about to pull my hair out I have a 94 3.0. Problem is when I get in it to take off 1st don't do it 2nd starts to spit and sputter like a miss at 2k goes away around 2400 then same with 3rd and 4th 5th is fine. Then after it warms up tada nothing wtf!
Truck has new plugs wires cap rotor and is timed at 6* like other members said is the right timing.
Sounds like the choke system isn't doing it's job doesn't it?
Big JIm
Ooookay!
Educate me Please
When the engine is cold there is a a choke system on all engines. This system adds more fuel until the engine reaches operating temperature. In the carbed engines there is a butterfly that keeps the incoming air directed to a certain location that will PULL more fuel into the mixture than is there after the engine warms up.
In a computered engine the computer sees the coolant temperature and adds the amount of fuel needed to run at that temperature. If the temperature sender isn't working correctly the engine might think it is already warm and put LESS fuel than it needs to run well.. Then after the engine is at the correct temperature that same mixture runs well..
Big JIm:hottubfun::wub:
Thanks Big Jim I know the first part I was looking for the last part you said Do you no where this sender is located and is it a easy fix
Set her to 10* and you will be good to go...
What is the correct setting I have been told 2 different ways I'm not a moron I'm sick of bouncing back and forth for he said she said I just want it to run right and not wanting to just throw parts at it
Also I need to pull the little plug right? under the radiator cap before timing it also right? this is my first 3.0 have had all others before and never had this problem
Still sputters a little but not as bad I will clean the sensors and I hope that will fix it
Finally replaced the side sensor in the air box I think it fixed the spit and sputter I'll find out tomorrow on way to work
The sensor in on the bottom part of the lower intake manifold right next to the heater core hose. Another one I would possibly clean or replace is the air inlet sensor, it's located on the bottom part of the air filter box.
Ok it's back is one of these the one's you are talking about
I cleaned the Mass air and replaced the one in the air box
I looked all over in my Haynes Manual and can't find any info on this sensor. It's really getting annoying that it sputters in every gear at 2k until 2400. Since I usually run 2k going to work every day So any more Info will be awesome Thanks guys
The one's I took pictures of are a warning light for over heating right and the other is for the gauge cluster?
Well I replaced this today and helped a little so I went threw the steps of tdc and re timed the thing looked to be 1 to 2 degrees off on timing also I had to wire wheel the balancer so I could get a good reading seems to run good
