Spilling much antifreeze liquid fron AC/system
islopez
Hi
My 92 Ranger xlt 3.0 standard
AC/ system is Spilling much antifreeze liquid, any suggestions to fix it, I put some pictures of the problem.
The problem started to day
Thank you very much for the help
is that the tube of the cover of the heater core? if so- your heater core is bad and leaking into that cover, which pours it out the opening in the firewall (which is better than it pouring out in your floor)
Definitely heater core. Good news is that if that is a gen 2 Ranger, the heater core is dead simple to change. Drain radiator - disconnect two hoses at the firewall - remove 2(?) screws from heater box inside cab - drop heater core through opening under glovebox - reinstallation is reverse of removal. Worst part is removing the rubber hoses if they've been attached for a while. Done the job twice so far and both times the hoses were adhered to the copper tube.
