fivespeed3.0
I've got a 2000 Ranger 3.0 Flex Fuel 5 speed. Yesterday I did the following:
Replaced brake pads, rotors, and calipers up front
Replaced both upstream oxygen sensors (Routinely done every 100,000 miles, the downstream one was replaced 2 weeks ago)
Removed and cleaned throttle body, reinstalled with new gasket.
Now every time I start it up, it revs to 3000 rpm. Most of the time I can get it back to normal idle by stomping on the throttle. After that its fine. What am I missing? I'm thinking either of two things:
1. I may have loosened/broken a vacuum hose.
2. May have messed up the wires/wiring harness for the TPS
Does anyone have any suggestions?
This is my daily driver and I need to have this fixed today.
