There are 3 screws plus one in the window knob which you need a pretty small torx for. There's one in the arm rest, one in the upper left hand (by side mirror except inside) and one on the bottom left of the door, all three are regular screws and the order doesnt matter that you take them off in. Then you pull the front part of the window knob off so you can see the center hole which the torx is down (I actually used a small allen wrench because i didnt know it was a torx till i took the first one out. haha.). Then once you have that off, you lift the door panel up and towards you a little, you'll have to wiggle it a little bit but it's pretty simple. I dont know if it matters if you have your windows up or down, but mine were up and it was really simple, i'd never taken off any door panels before today and i took both mine off, removed my speakers, and put wiring harnesses on for my speakers which arrive tomorrow in about 40 minutes. Good luck!
