cumberlander
- Nov 1, 2007
- Age
- 42
what is a good brand of spark plug and wires to use?
the only reason you would need to change anything relating to your plugs or wires is if you are plannin on runnig higher voltage through them, and increasing your gap.
no higher volts....no change
The actual factory original plugs in most 4.0's are "unobtanium"
the factory (to save a little money) uses different plugs on the left and
right bank of the engine.
This is because that six tower coil pack is really only three coils
and the firing to one bank is reverse polarity.
the platinum isn't really "needed" on both electrodes
so on one bank the "tip" has a platinum button
on the other side the platinum button is on the ground electrode
However the specified replacement plug, the one I mentioned above,
The Motorcraft AWSF42PP is a "double platinum" plug specifically made
to work on EITHER side of the engine.
I guess ford figuires that the double-platinum buttons will prevent people
from putting single button plugs on the WRONG side of the engine.
AD
