- Aug 6, 2007
- Age
- 48
- Berrien Springs, MI
- My credo
- If you can't go through it or around it, then go over it.
How do you know if you have a broken spark plug without disturbing the spark plug?
my Camry has a random misfire on cylinder number 6. I moved the coil to another cylinder and it still have a random misfire on cylinder number 6.
when I attempted to remove the spark plug from cylinder number 6 I can rotate the plug 10 degrees either direction then hard stop. Because of the ease in which the plug turns that 20 degrees made me not want to put any force on it.
