I need to clarify what I meant when I said "impossible to stall"
I'm talking about letting the engine settling into idle in 2nd gear
& low range then attempting to hold the truck with the brake.
In my truck the brakes lose, and I have really good brakes.
I'm afraid to try it in first for fear that something expensive will break.
How good are my brakes?
I'm NOT going to say that I could lock the wheels with a full
load of fuel (84gallons) in the truck and a ton of rock in the bed in bare
feet with a sharp thumbtack taped to the brake pedal... but I might
try it if the thumbtack was kinda dull...
you really want to be very gentle with my brake pedal or the truck bites back.
But those brakes are no match for low range in 2nd
as for a limited slip or a locker causing issues in the snow?
I think you missed something...
a Locker or limited slip only ensures to varying degrees that both wheels will turn.
Having both wheels turning makes it more probable that the truck
will be able to move... but here's the rub, don't assume that the truck will do so in a "nose forward" attitude.
In 2wd with a limited slip I often wished for wipers on the side
windows so I could see where I was going while climbing the
(steep) hill to my house.
But if one side window became too snow covered a simply jerk of
the steering wheell would get the truck to climb the hill "the other way"
so I could look out the clear window...
I really freaked out a friend by doing that one snowy afternoon
then again I doubt that particular friend was all that freaked,
he was in the car one afternoon when he saw me lock all four wheels
and abrubtly turn the steering wheel, allow the car to rotate about
30degrees, then release the brakes to demonstrate a collision avoidance
manuever... while actually avoiding a collision...
the car changed direction like I had bounced off something...
It never entered his mind to ask how I knew it would do that.
AD
