Bird
Can you go into more detail about how to tune this area? For this could be the information I was looking for about my build. As you are aware from a different thread I was/am having that small problem, and after the injector swap tings have mellowed out for the rich burning, however, i still feel that she isn't running 100% yet. any knowledge on this fine tuning will be appreciated. (links??)
thanks
You have to keep in mind that adding headers, swapping cams, porting heads, etc change the 'flow' in an engine (volumetric efficiency), thereby necessitating fueling changes. With a 'properly tuned' MAF based system, the MAF transfer function will 'usually' be able to accomodate this increase in air flow and keep the fueling in line as long as the MAF doesn't max out at WOT. Adding headers and porting the heads usually don't require a retune as all you're doing is increasing flow - throw a cam into the mix and everything changes. All of a sudden, the valve timing events play a role in the fueling. Throw some overlap between the exhaust and intake valves and now you're allowing some of that fuel that the PCM / tune thinks is going into the cylinder to combust to actually go out the exhaust valve - resulting in a leaner combusion condition that under closed loop will be compensated for by adaptive fueling, but under open loop wouldn't. A tweak would be needed either in the requested fuel tables or, better yet, in the injector timing to delay the firing of the injector slightly - keeping the fuel in the intake stroke. (this will also help get rid of the raw gas smell in the exhaust)
Changing out heads or pistons for more compression (ie: adding 95+heads to pre-95 shortblocks) throws another factor in the equation - you will usually need higher octane fuel to control detonation and also increase fueling a bit under open loop operation to keep A/F ratios in the proper range for best power.
If you change to different injectors or a bigger MAF, now closed loop operation will be affected - you have to change the injector parameters so that the PCM will know how much pulsewidth to apply for proper fueling and the MAF transfer function will have to be changed out to reflect the different values that the new MAF will report for airflow. Some of the aftermarket MAFs claim to be calibrated for specific injectors, but there are several assumptions / 'SWAGS' in those calibrations. Also, contrary to popular belief, the factory Ford MAF's are not calibrated for specific injectors - you can't just swap in a bigger MAF from another engine with the same size injectors and expect it to be good.
OK - end of today's lesson.
Bird
ps. SWAG = Scientific Wildass Guess
