RobbieD
2.9l Mafia
- Aug 6, 2007
- Georgia
- My credo
- Toonces drives a Ranger . . . . just not very well.
Welcome, BroncoNewb. Good on you for saving that old B2.
That one looks like a true "diamond in the rough", and it sounds like it'll be real gem once you get going on it. '84 is a good year, and it looks to be optioned well (vent windows, flip-up rear glass, AC). Plus, it should have the C5 auto instead of the trouble-prone A4LD.
I have an '84 Ranger; I like the 2.8L, and the Duraspark conversion does have a lot of advantages- better drivability, more reliable and really simplifies things in the engine bay.
But the only real "if it were mine" advice ("two cents worth" actually) I can offer would be to focus on getting all of the truck's mechanical work done and up to snuff first. Suspension, steering and especially brakes. Get the cooling system top-notch, and get a cooler on that auto if it doesn't have one already. If the motor doesn't have obvious crank seal or oil pan leaks, try doing just the valve covers (notorious for massive leaking) and see how it does. A little more work, but new valve stem seals will also likely cut oil consumption. Assume that the truck has never had maintenance, so catch up on all maintenance items.
I would though, short-term on the body, get that surface rust off of it and get some good primer on it.
Welcome to the madness, and good luck!
