Somethings rattling in my 2007 ranger
  • Thread starter Thread starter Mike Tonon
  • Start date Start date
Mike Tonon
Guest
The sound is either coming from inside the doors or in the panel just behind the doors (reg. cab). It sounds as if the doors arn't shut all the way when I drive over a bump, but they are. I took the rear speakers out yesterday and felt around. The wheel that whinds the seat belt up seems a little loose. Anyone else have this problem?
Also, where can I get decent vinyl floor mats for not too much money? Before I had 15,000 miles on my truck, the OEM mats already had holes and the dealer wants around $70 for new ones. I like the design of the oem mats, but the material seems cheap and molded a little thin in some spots.
thanks
The rattle may be the same as what i had. I have an 06 fx4 and when you shook the rear door in made a thump sound. I finnally broke down and pulled the panel off and it turn out to be a three inch square peice of that fibre-y card boardish insulation something or other. It was suposed to be stuck in there to do something but took it anyways. No more rattle.
Mine's a regular cab, but maybe that same stuff is in the front doors. I wonder if I should bring it back to the dealer again and demand they take the door panel off and figure it out. Thanks for the tip.
