1999 ranger 4.0 @200,000 manual 4wd
I recently checked and filled transmission, and front diff, and transfer case, then this clicking under load started, I rechecked the fluid levels, made sure nothing was overfilled, checked three sources as to type of fluid.. the little black rubber dust cover on the transmission, i crawled under and listened while it was running, and removed black rubber cover and it sounds like its coming from there, and all gears but forth.. Im no mechanic, I've owned ford rangers for 15 years.. I know the basic idea behind the parts, but nothing as to what this might be. Or if it's related to the fluid. at first I thought maybe the transfer case was stuck between gears, or 2 and 4wd..
Any help would be greatly appreciated,
i remember something about forth gear being the only gear thats running the same RPM as the engine, if so, is whatever compensates for the difference stuck, or burned up and clicking.
this sucks, my only ride.
