Some general hp/tq & axle combo guidelines?
Vexarana
U.S. Military - Active
I've been reading up on a few different engine and axle swaps, and for right now I'm thinking I should do the axle swap on my truck first and then do the engine in a few months.
What I don't want to have to do is swap axles multiple times, or worry about beefing stuff up too much in order to avoid breaking it before i even start souping up my engine I'll be swapping.
Right now I have an old OHV 4.0, which is somewhere around 160 HP and 240 tq's.
But what I want in the long run is a 4BT with somewhere around 300-400 HP, and that would put it somewhere near 700-900 tq's.
Do I need to put a full 1 ton axle underneath that?
I was looking at a D44 TTB front, modding it with equal length beams, and making it have a crazy amount of travel. Then for the rear I was looking at a 10.5/10.25 or a D60.
Some of the threads have cast doubt on running a half ton with that many horses, and especially the tq's a 4BT puts out... makes me somewhat doubt it.
Basically, does anyone have some general guidelines of what axles are suitable for what hp/tq/tire sizes?
Forgot to mention I'll only be running 35's on my ranger. Most likely never larger than that.
TLDR:
4BT 350 HP 700 ftlb
D44 TTB front D60 rear? Or get something better? (Disc preferred, or able to upgrade to disks later)
EDIT : Forgot to mention I'm wanting to 4-link the rear to lay down the power off stoplights and other foolishness, and coilovers on the front.
TLDR:
4BT 350 HP 700 ftlb
If you have the money for a 700hp engine and coilovers Run d-60's or 14 bolts (d-60 outer steering stuff for a steer axle) f&r.
A d-44 is not a good abuse axle for 300hp...
definately want more than D44 up front with that kinda torque/power.
for piece of mind at least. im sure the 44 would hold up, but the question is for how long lol
D70 10.25 or 14b for the rear. a 60 wont hold 900tq without better shafts.
ahh I'm trying to avoid throwing a 500 lb axle under each end. What about the D50 TTB? How much could that hold? I'm buying a 250hd in about a week, and was going to sas that with a d60 or possibly larger. The axle I put under that I'll be buying though. If. I need to put some heavier weight axles under my ranger anyways, id hate to waste a TTB 50.
I could always change plans on the engine, too. Keep the injectors a little bit smaller or cut out methanol. What would a mildly built D50 TTB hold? 250hp/600tq?
A ttb prolly wouldnt hold up imho.
More hp/tq = bigger axles. A solid axle 60 is wayyyyyy stronger that a ttb 50. Not to mention lots of aftermarket parts when/if you break something.
Sorry, not really an axle guru. Is it more about the u-joints on a TTB or is it the axle shafts?
The inner shafts on a TTB 50 are the same size as a dana 44. The 50 also uses smaller joints than a 60 front.
Did not know that ^^
What about a solid d-50? Is it smaller shafts too?
Just wondering cuz I know a local goon that put one in a FS Bronco and swore it was a d-60. After he bought a 60 locker and it wouldnt fit he admitted he was wrong.
The Dana 50s Both TTB and solid are like a 28/35 hybrid in a ranger. Big outers like a Dana 60 but smaller gears, carrier, and inner shafts.
The SA D50 could be compared to the D28/35 hybrid (a D50/60 hybrid).
The TTB D50 is kindof it's own thing (like the earlier D28 is), it has little in common with any other axle aside from the hubs/rotors.
So anything safe for a 44 would be safe for a 50 prettymuch? Are there any advantages then to a D50 other than it would come straight out from under my F250 when I SAS that?
Since it was put under the 7.3 PSD it should be good for 200-250 horses and 500 tq's? I'm interested in spinning the 4BT but probably not as fast as you need for 300+ horses..
I don't think it would be worth the hassle to put a TTB D50 under anything that didn't come with one.
I don't think a solid D50 would be too bad though...
not axle related, but i saw 4bt mentioned so i figured id add... if your shooting for the 3-400hp mark find a p-pump'd engine if you havent bought the engine yet. going to take a lot to get up to 400 reliable hp
