Solid Front Axle Swap Poll (Whatcha got?)
What solid front axle have you swapped in?
  • Total voters
    292
I used a FSJ/Waggy front and rear on Waggy leafs.
A D44 should hold up just fine with my 33's
EB Dana 44 swap, built a 3 link setup with a trackbar. 8" lift ttb coils
What the hell? It won't let me vote more than once. I've swapped in more than one of those.
Mine will be a Dana 30 off a 1990 Jeep Cherokee. Hopefully done soon!
Other. I'm swapping in 2000 Superduty axles, D50 front and 10.5 Sterling rear. It's only on 32's in the pics but it will be getting 39's when alls done. # link front and Exploder leafs rear. Approx 4" of lift over stock. As of right now 116" WB and 83" wide.
how much wider is the waggy than stock rbv front end and same question for an EB d44? this is something i'm looking to do but i can't choose which axle i want. It seems that a d30 is the cheapest but the weakest for the swap... my area anyways thanks for answering the noob questions guys
76 HP Full Width Front complimented with matching 76 Ford 9" in the Rear!
The bronco hasn't done much since these pictures were taken... during the run I blew the trans and steering box along with the front shocks! : )
Since than I've painted it and added a 93 4.0 and replaced the blown trans with an M50D
Nem
