ranger_rick
- Apr 17, 2013
- Automatic
My 106,xxx 4.0L SOHC has the dreaded timing chain rattle (rattles at start up and 2500-3500 rpm)
I came across this thread (see below) and i want to give it a try.
http://www.therangerstation.com/forums/showthread.php?t=13532
But i am concerned that 10w40 might be too heavy...i dont want to create a problem by trying to solve a problem.
a little back ground:
the engine doesnt burn oil and i am currently running mobil 1 full syn 5w/30. I switched to full syn (last fall) after running dino for many many miles and initially it did make a difference but now the rattle is back.
I noticed that during the winter months (i live in upstate new york) that the rattle wasnt as pronounced at either start up or after warming nor was it present at 2500-3500 rpm
now that spring is here and the morning temps are above 30º there is that nasty rattle and it doesnt matter if it warm or not the rattle is always there at 2500-3500 (much worse with engine is warm)
so i started thinking that maybe switching to heavy weight high end syn might be good idea...
the obvious choice would be to try 10/30 but i checked the specs of mobile 1 syn and amsoil there isnt much viscosity difference (@100 or @40) between a 5/30 and 10/30
maybe 5/40? or go for glory with 10/40
thank you in advance RR
