Broosedamoose
DaMoose is lose!
- Mar 10, 2012
- 4.0 V6
- Automatic
- Tire Size
- 31 x 10.5
- My credo
- Coming in second just makes you the first loser!
I put a dry nitrous kit on my 07 Ranger 4.0 and I'm wondering about the bottom end. I read a few post that said the pistons were only good for up to 7-9 Lbs of boost. When I first tested it I started with the 25 Hp shot and worked up to the 100 Hp shot datalogging each time. I know the general rule of thumb is you can add a nitrous shot up to half of what Hp the engine makes on it's own. Since the SOHC makes 207 Hp that would mean a 100 Hp shot. However, when I tried the 100 Hp shot the fuel trims were a little lean. (1-3%) The stock fuel system is just not quite enough to keep up. I backed off to the 75 Hp shot and it was fine. But after reading the posts saying the pistons are only good for 7-9 Lbs of boot I wonder if the 75 Hp shot is too much. I don't really know how much boost it adds. I don't use it that much any more but I'm wondering if it's a ticking time bomb and I should drop to the 50 Hp shot.
