Smoke test pointers with persistent P0455 DTC
Featured Build Threads
Setting up to perform the same tests on my 2000 4.0 Ranger. Some good stuff on this thread to watch for!
Good job posting the update!
Well 2 months later and 5 tank refills, P0455 is back. Ran another smoke test, no leaks using the bottom hose of the Purge valve that goes back to the gas tank, vapor canister. Used the top hose and had smoke coming from the top of the purge valve, the egr and the IAC vent. I may have to get a diagnosis done at a shop since my scanner is not bidirectional. Are all 3 of those leaks normal?
I just watched a video showing how to test the purge valve (unplug it with engine running and remove bottom hose going to gas tank, if vacuum on the port, its bad) test showed no vacuum, so purge valve appears to be okay. It is a Motorcraft part that I replaced 1 year ago.
Replaced the vapor canister and vapor canister vent valve. No change, P0455 is back. Suspecting a wiring issue. I have good tank pressure, no smoke leaks, working purge valve, new vapor canister, new vapor canister vent valve. Only thing not new is fuel inlet assembly and thats not all that expensive. There were numerous mud daubber nests all over this truck when I got it. Wondering if the fuel inlet tube is clogged. May replace it and if thats not it, pay my local Ford dealer a $109 diagnostic fee. I did try to bend back the flapper on the nozzle hole as it was bent slightly open, got it pretty sealed back up flat if that makes sense.
Any ideas? I am going to attempt some diagnostics with Forscan since my Topdon 500 isn't bidirectional.
Forscan shows no reading from the fuel tank pressure sensor. Purge valve and vapor canister vent valve are functioning. Still no leaks from smoke testing. Ordered a new tank sensor. I highly doubt there is a leak within the fuel inlet, other than the possibility of the clogged vent line on the side of the fuel inlet. Thats an easy repair/replacement if this tank sensor doesn't cure it. After that it's time to remove the check engine light bulb, lol.
Replaced the fuel tank pressure sensor today. When I monitored with Forscan there was nothing reading from the sensor. Today after replacement it was reading -450, the range was showing as -7500 to +7500, plus it was putting out a steady 2.43 volts, so it appears to be working. Problem is that evap tests aren't commanded by the PCM if the fuel level is above 3/4 tank. So after a few miles and some more monitoring, hopefully this takes care of it.
Well that didn't help.
Appears after 80 miles, 3 days to and from work and numerous drive cycles that the fuel tank pressure sensor was the culprit. Lets hope it stays that way (knock on wood). I keep scanning every 15 miles or so and no codes, stored or otherwise.
I think P0455 was stored for the first 1/4 of the tank, then at 3/4 it popped up and since clearing it, it has stayed gone and I'm below half a tank. The evap system only commands tests between 3/4 down to 1/4 tank.
Well 2 weeks and 400 miles later, no code. Time to spend some money on something other than emissions! Window tint coming up!
  • Smoke test pointers with persistent P0455 DTC
Featured Ranger Based Vehicle
