- Sep 16, 2020
- Montana, USA
- 4.0 V6
- Tire Size
- 265/75 R15
I opened up my rear diff to see exactly how messed up it is. I already knew I was going to need new bearings+seals, so I have that on order.
When I cracked it the fluid came out all metallic, then I found this gear all chowdered up and throwing shards but I haven't found any info on what it is. My '01 has abs, so I was thinking it might be a speedo gear for the wheel position sensor on top of the diff?
The rest of the diff doesn't look too bad I don't think. The backlash is 55thou right now, but I was thinking that's probably from the bearing wear. The kit I ordered has the shims, too.
