427ford
About 90K ago, I had a reman 5 spd put in our '94 4x4. Maybe the last 40K or so, the shifter has progressivly gotten more and more play in it. Tranny works fine, other than the sloppy shifter.
Are there any bushings or other parts that are known to wear on these shifters / trannys? If it's a shifter issue, as I suspect.. can I access it through the top or is pulling the transmission required?
