Slave n clutch help
Royd
Springhill fl
Put in new slave with new used tranny gravity fed the slave and foot bled master.put new clutch and plate.soft pedal grinds a little when going into 1st and 2nd gear but when in reverse for about 10 feet locks up..please rell me what to do next...oh also changed coils oxygen sensir fuel pump crank sensor master cylinder icm ..i need someones help please
I'm not much of a mechanic, but I'll take a wild guess that you've got air in the line. A general rule would be that if it's grinding going into first and second the clutch isn't disengaging completely, but then it should grind going into all gears, I'd think.
I'm going to take a second wild guess that your clutch is the least of your worries, at this point, and you may have transmission issues.
Hmmm,, "about 10 feet" is about the same distance of one tire revolution for large tires. hopefully you don't have axle problems.
with the engine off, can you shift thru the gears without the clutch?
