So for starters, not my first go round with these Ford hydraulic slave systems. I know how much of a pita they can be. That being said, I have read no less than 2 dozen posts, threads and watch just as many videos on possible solutions. I'm frustrated and just don't know what to do at this point.
96 2wd 2.3L 5spd (I think it's the 55 transmission). The line at the "quick connect" fitting at the slave cylinder popped off on me in the middle of town. Had the truck towed back home and that's when I found the issue. Ordered and new master cylinder system that was pre bled so I would have to fight with it. The system I ordered included the reservoir, pressure valve and lines pre filled and pre bled. When I installed the new one, I gravity bled at the slave bleeder screw and made sure it was all just fluid coming out. Made sure the reservoir was topped off and then attempted to use the pedal. Had low resistance and almost no travel in the pedal. Once again gravity bled the system. Tried the pedal and still no improvement. Used my mighty vac pump and vacuum bled from the reservoir and was able to get a few small air bubbles out. 3 days I've been bleeding this system and still have no pedal and it won't shift into reverse or first from a stop. I don't know what else to do.
