96 ranger. Brand new LUK clutch kit, flywheel, master and slave.
Somehow air is getting into the slave cylinder. If I disconnect the master cylinder from the slave the pushrod is solid. Zero play at all. System was bleed as per service manual. Worked fine for a few hundred miles then I lose firmness in the clutch. If I rapidly pump the pedal wait a few moments and repeat 2 or 3 times. Then open the slave and close slave while someone pushes the pedal a time or two pedal firms up for a few hundred miles. I'm stumped. I really don't want to pull the transmission again. Any idea how air can be entering only the slave?
