Engine won't die like that if it's 1 tooth off, lose power with lower compression but not die.
More than 1 tooth off and the valves starting hitting the pistons, and it would still run, I know that for a fact, unfortunately, lol, friend used the wrong timing mark on his motor, started right up but had a heck of a lot of lifter tap........wasn't the lifters tapping
Now the chain could have broke, that would kill the engine and at speed probably bend the open valves over pretty good(or bad), so they are no longer in the way of the pistons, cam shaft is no longer turning..
That would make the starter turn the engine over faster since there would be pretty much 0 compression on all cylinders.
Hopefully it's just a bad wire.
