adsm08
Senior Master Grease Monkey
Ford Technician
- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Tire Size
- 31X10.50X15
Would you trust a single flaring where a double should be?
I had a blow out at the end of the day at work, my tool wouldn't bite the steel line hard enough to smash the first stage, so I just ran the cone down to get something the nut could bite to so I could get the line down and get home to where my better supplies were, cleaned it off, tested it gingerly and headed out.
When I got home I stood ont the pedal as hard as I could with the engine running, and it felt like it was holding. I got under, inspected it, and the line is still dry.
So I guess the question is, would you trust it, or would you make a new line that is flared properly at both ends?
