Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I think you mean a spool, a locker has the ability to lock and unlock so you can turn without skipping the tires. A spool locks both axle shafts together to spin at the same speed all the time so you will chirp or skip the tires in every turn which will wear your tires out quicker.The down side of lockers is increased tire wear.
Yeah, this brought me back to an older thread where "locked in" got tossed around far too much, and it seemed like the twilight zone. "Engaged" is more the term I suppose, even though it is locked (at least I cannot unlock it, it will do what it does regardless) The front rarely sees this type of turn while Engaged, and I just tested the rear in reverse 2WD and it will not grab no matter how sharp I turn it.What do you mean by "locked in"? The limited slip isn't a locker so it is never "locked" however there is always pressure being applied to the clutches.
Agreed. And new bearings and seals are all included.
Do you like the Trac-Lok?
And it's never required a rebuild?The one I stalled myself I liked, but I only had it for about 1000 miles before the truck got totaled.
I also have a factory 8.8 with a trak-lok in it on my mustang I love it. I believe it has around 120,000 miles on it. That car is fantastic in the snow.
Like 00t44e said, the axles aren't locked together. Pressure is applied to the clutch packs that limits how much they slip. Most limited slip systems increase pressure as more slip happens to a certain point. Typically somewhere around 50%. This is a simplistic explanation though. There is much more to it and more than what I can explain. Ronny Dahl did a video or two on the subject comparing open differentials, limited slip differentials, and locking differentials. Now, he is going at the subject from an off road driving perspective. So, for an only on road driver, the information is going to be a bit skewed but useful none the less. I'm sure there are other youtube channels that cover the subject as well.
And for the most part, it drives like a standard 2WD, open style differential...except for burnouts, gravel roads, and heavy snow?I've never rebuilt it, and it still works properly. The only maint that's been done is a an oil change with new friction modifier after about 100K miles or so. A lot of those miles are highway miles, but there are quite a few burnouts and drifting around in gravel lots type stuff too.
that is what happened to my wife and why she wanted the lsd removed from her car. it went around on her on a road that someone had spilled gravel on at the edge of a driveway
Three words here, "except in snow." And of course, there's no snow ever in southern Maine.Idk how all you guys drive who say you've experienced accidental/unintended back-end dancing but damn.. I've never ever gotten any of that except in snow lol. It's a bummer to be honest.
