OilPatch197
- Sep 23, 2007
- Age
- 96
- Automatic
Okay I need to setup my garage for Rusty, oxidized fastener removal.
Got some rust buckets coming up that I need to do some work on.
Fastener range will be from 3/8ths to 24mm, bolts to long studs(stupid gas tank bolts) fuel/brake lines(some metal lines screw DIRECTLY into aluminum, now tell me that isn't going to get stuck?) to leaf spring brackets.
But before I list what I have. I will tell you what I have learned(correct me if I'm wrong!)
PB Blaster or other penetrating oil for initial soak.(NOT WD-40)
Snapped off bolt heads- Weld on nut OR use cutoff tool to slot, heat with torch(?) and use air impact chisel tool.
Stripped bolts- Drill out and tap for larger bolts if room allows, OR use Helicoil. If bolt is stripped and will not pull out, use a slide hammer with vise grips welded to the end.
if bolt will absolutely will not loosen or is so corroded, just cut the nut off with the cutoff tool.
Use six sided sockets with a GOOD impact wrench, either the fastener will come loose or it will twist off!
NAPA crowsfoot wrenches std and metric. Evercraft.
Clean rusty threads with die grinder with wire wheel before PB Blaster.
THE TOOLS I HAVE NOW...
-4 1/2" Makitia angle grinder converted to 4 1/2" cutoff.
-a campbell hausfeld impact gun that has to beat on a lugnut forever
before busting it loose.(like 200 ft/lbs of torque)
- 3" pneumatic cutoff wheel
- I only got a hand impact driver.
- Air Ratchet
- I only got a MAPP torch.
- die grinder pneumatic tool with wire wheel
- Standard and Metric die set
-20 gal air compressor with 5.8 CFM 3/8ths air hose.
- Hobart Handler 135 MiG welder w/ Co2 Argon mix.
-high speed drill bit set, 3/8ths drive electric drill.
THE TOOLS I DON'T HAVE OR ARE IN QUESTION:
I feel my Impact wrench is weak.
I feel that the hand impact bits are unhandy in tight places(want air chisel)
I have no Helicoil kit
My torch is a single cylinder MAPP gas, will that get the bolts hot enough?
I have no bolt "extractors" is it something I would need?
- Air Ratchet
