Rangerslug99
- Nov 9, 2007
I have had my ranger going on 8 years now. it has 130,000mi and has been drove mostly city streets with the occasional off road.
My truck is bouncing like crazy, more so than normal, and has seemed to be getting gradually worse after i go over a bump or rough road. I want to get some new shocks, but i am not quite sure what to get. The wife has been nagging me about the "rough ride" my truck has. SO, i figure it may be time to replace these things.
About 3 years ago, i had a front end alignment done my truck, the mechanic said he could only adjust so far and needed a kit to get anymore adjustment. Been too long and i cant remember exactly which adjustment he was referring too (camber, caster, or toe.) I had him adjust as far as he could and leave it. I was having wear on just the inside of my tires is why i had it aligned. My tire wear in the past 1 1/2 years has been even.
having said all that, is there anything else i should look at or check when i replace my shocks? I am planning on replacing all of them.
Thanks.
Rangerslug
1999 Ford Ranger Sport Ext.Cab
2.5L 4 CYL, 5-speed, 2wd.
Thanks.
Rangerslug
