marriedmanw
Thanks for the suggestions that I've recieved on my other post about the serpentine belt. Background: Recieved a chirping sound with new MotorCraft belt, and shop advised to replace belt tensioner. Replaced belt tensioner and chirping remained. Changed the motorcraft belt with dayco belt and all quiet for 3 weeks then sqealing/chirping returned.
Which brings me to today. Removed the dayco belt and noticed the edges were worn in spots. I can see the seam (white seam) on most of belt but in two places there are flat spots where I can't seem to see the white seam. My thoughts are if the belt is rubbing or a pulley alignment wasn't correct wouldn't it rub the entire length of the belt?
The chirping with the Dayco belt will go away after driving for 20 minutes. Put the motorcraft belt back on and still chirping regardless on time driving. Following another thread they resolved problem by putting on goodyear gater belt, but I don't want to ruin belt if pulley isn't alligned or belt seams will rub off. How do you test pulley alignment?
I've had this vehicle for six months now and it's really becoming a PITA, but I can change a belt in less than 5 minutes now.
Thanks.
Thanks.
