- Sep 19, 2025
- Age
- 55
- Williamsburg
- State - Country
- VA - USA
- Other
- 2007 Volkawagen MK5 Rabbit 2.5
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Manual
- Total Lift
- None yet ;-)
- Tire Size
- 265/75/16
- My credo
- Facta Non Verba
Did you do a thread or write up on the Escape seats?For the Ford Escape seats I swapped into my Ranger I separated the tracks by grinding off the stops and tabs and sliding the two rails apart. Then put the rail-half with the Ranger feet onto the rail-half still bolted to the Escape seat.
For that swap, the Escape tracks were positioned wider on the seat than the Ranger's so I had to add a little bit more foot onto the outside feet to make them work. But if your rails are the same distance apart it should be a straight swap.
I'm curious/interested.
