SEATING the flare nuts on new stainless hard lines...
fixizin
FoMoCo is forcing me to buy a 'yota
⭐Supporting Member
Fort Lauderdale
FL - USA
Other
FLEX-fuel, baby!
Drive
0" bone stock
P235/75R15
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
... how much crunch/torque? Seen some how-to's that say to tighten and loosen 3-4 TIMES before the final cinch... what say ye, RKIs...??
I'm using the little 5" 11mm wrench... can't get too much crazy torque with that... ?
:unsure: i break way too much shit to say no.
So when it just starts to twist the tubing, that's enough? TOO much?... or does it just mean I was supposed to lube the working end of the flare nut? :icon_twisted:
Durn, hope I haven't hosed muh hard lines... could always RE-flare the ends, right, only lose a couple mm? :eek: Pipes came a bit long, had to do a little large radius bending to get the ends to be near-neutral in their fitting holes.
Rained out for tonight, tomorrow I'll bleed the fronts, refill the MC rez, then start bleeding from the right-rear with my $10 ShAmazon hand-vac pump. #LeakCheck
I don't have enough experience with stainless to give you an educated answer.
I would think if they had proper flares just tighten them up like steel line. If they leak... back em off a bit and tighten them again a tad tighter.
