Seat Swap. 1989 to 2000 Ranger
crowneagle
I've got two Rangers. My old one is an 1989 x cab and I've got a 2000 x cab. Will the 89 bucket seats bolt right into the 2000? The 2000 has the split seats and the guy who owned the truck was a slob. I love my 89 seats and want to put them into the 2000. After I finish scavenging any parts, I'm selling the 89.
Suggest you check the tech articles:
http://www.therangerstation.com/how-to/interior-and-interior-electronics/
There's always a lot of interest in swapping seats. Based on what I've read, you have at least a chance of bolting your 89 seats onto the 2000 seat-tracks (of course any power stuff that's built ino the lower seat tracks gets left behind or acquired with the new set.
My direct knowledge is of the older stuff, and I can tell you you have 0 chance of unbolting the 89 seats with their original tracks and dropping them into the 2000.
Ranger floorplans were the same in the gen 1s (up to 1988) and gen 2s (1989-92). Starting in 1993 (gen 3s), a metal hump was inserted crossways across the cab, where the front of the seat brackets bolted into, instead of into the floor like on the older rangers. I was able to drill out the spotwelds on a 1994 (or 4?) supercab, hump, and ren=move it and the seats and use the seats as templates to weld the hump into my 91 supercab and mount the 93 seats in the 91. This of course involved removing the carper in both vehicles, among some other stuff.
Not sure if the floorplan changed again between 1993 and 2000. Also the seatbelts may or may not be something that will marry up between 1989 and 200 (one more reason to use your 2000 seat tracks, if you can.
Good luck!
Split bench seat
My 89 are bucket seats, while the 2000 are the split bench. I suppose that pretty much rules out using the old seat tracks. Thanks for sharing your knowledge. Looks like I'll be buying some decent seat covers. Yuck! The 89 seats are awesome. The 2000 seats are awful.
Do you know how many years use the same seat as the 2000 ford ranger? I might try to find a good one in a junk yard.
On older ranger vehicles, my impression was that the bucket and split bench tracks bolted to the seats in the same way, and that you could use either under buckets. (One-piece bench seats, of course have a different setup).
I did get the impression that, at some point seats were getting welded to the lower tracks, making this sort of swap impossible (or at least not easy). But again my impression was this was later on than 2000.
The tech article I gave the link for above indicates all manner of Ford seats that can be married to Ranger tracks. As I said before, newer rangers are out of my direct experience, but I am quite sure someone will stop by with some helpful advice.
I have seats out of an '05 in my '86, and I had '04 seats in a '96 at one point. The newer seats were out of extended cabs and went into single cab trucks. I had to do significant modifications to make the older seat tracks work. Newer tracks are not welded on, but are riveted on and the rivets will have to be ground off.
Seat belts are also different - late model trucks have the clip mechanism attached to the seat and your current belts won't latch into it. So you have to swap those too or keep the belts with the truck.
I'm surprised you like the older seats, I like the newer ones a lot. Maybe my old ones were just worn down.
