lordkyleofearth
I am going to start a new thread so that I can clarify the issues and hopefully find a solution (the old one is sort of a mixture of suggestions and things I've tried...)
The problem:
-It backfires, hesitates, idles rough and has very little power.
-Engine was rebuilt ~10k miles ago (rings, gaskets, bearings)
-The problem worsens the longer the truck runs.
-Check Engine Light is on, 2 codes thrown P0135 and P0141. Both were on long before the problem began.
-When it dies, the fuel pressure climbs to 40#s as the engine sputters and dies. (3:35 in the pressure test video) I don't know if this a symptom or effect.
Things I've checked:
-Fuel pressure checks out. (Between 25# and 35#s at idle/coasting, 40#s under WOT)
-No gas smell in pressure regulator's vacuum line (line is not plugged either).
-I have not been able to locate any vacuum leaks (aerosol spray test).
-I have installed a new fuel filter.
-Plug wires are routed correct.
-Plugs and wires are new, gapped correctly.
-MAF has been cleaned recently.
-IAC valve has been cleaned several times.
Things that have been suggested, but I haven't gotten to check:
-EGR could be clogged?
So that is the long and short of it. The problems seem to come and go, sometimes they are worse than others. I took the truck out the other day and drove it around for a bit and it was totally fine, not a single problem for 5-10 mins. Now it won't even idle.
I really doubt the EGR is the problem, if it were anyone with an EGR block-off plate should be having the same problem, right?
Could it possibly be a failing coil pack or injector?
*Video of driving fuel pressure test: http://www.youtube.com/watch?v=uzxkCnUuy_4
The problem:
