TSB Number: 870197
Failing Component:
Engine And Engine Cooling:Engine
Summary:
Incorrectly installed gear driven camshaft position (cmp) sensor synchronizer assemblies causing surge, loss of power, malfunction indicator lamp on and diagnostic trouble codes P1336, P1309 and P0340.
Why did you set to TDC instead of just marking the alignment when you took it out, just curious? You could be just like a tooth off or something .
If you take off the cam sensor and put the alignment tool ontop of the cam synchro, and rotate the engine, when the tool sits down on the synchro, you know you're at TDC. That's how you're supposed to do it for replacing the cam synchro with the TDC method.
If you're just eyeing it up, I mean you could be off a little bit in either direction, then when you popped the new synchro in, it could have gone a tooth to the left or right.
So I mean you could rotate your engine by hand, and if your harmonic balancer is in good shape, it has timing marks on it. It will say TDC then have numbers...when the 0 is just in line with the crank sensor, you are at TDC. If you can't read the numbers, it's the fifth tooth down from the big gap.
So I would do that...and get the engine at TDC. Then check your cam synchro. If the synchro finger is right in the middle of the gap (on the cam synchro), it's right on. If it's 180 degrees off, rotate the engine again one turn and make sure that finger is right in the middle of that gap on the cam synchro.
If it seems off, take it out and adjust it to where it needs to be.
