saginaw power steering hose questions
kmd1776
im trying to figure out if the stock pressure hose for a 2003 ford ranger will work into this 79 thunderbird saginaw pump. from what i can see the flares are 2 different sizes. im afraid this is going to cause leaking.
has anyone run into this problem before? if so what other hose can i use that will fix this problem.... any aftermarket adapters?
ok so i finished up doing the swap, and sure enough the pump is leaking... does anyone know of any place that sells power steering adapters? if not does anyone know where to get custom made power steering lines??
