- Dec 26, 2007
- Age
- 40
- moving with the army
It will work basically the same for any lighted start button. I chose one from an S2K for the looks and how itll fit in a cigarette lighter hole.
Wiring the relay into the column. If you splice into the red/blue wire then you can still turn the key to start the truck. If you just cut the wire and run it straight to the relay then only the button will start the truck.
The wiring on the button itself. The connector is the power connector from an old floppy drive.
and how it looks mounted in the dash.
This was on an 03 so other years might have a different color wire in the column harness that you connect to. Just look up a diagram for a remote start setup and itll tell you.
Hope everyone enjoys this simple mod. I did it because the lighter did not work.
