they are both ext cab trucks. I plan on using the cab and front fenders off my 93 to put on a 99 that im buyin that has been flipped on its side an almost rolled over but very nice condition. Hopin that the 93 cab will work does anyone have any ideas? PLease help ASAP
Yes and no. Physically the same size, and mounts in the same spots.
The firewalls are completely different and incompatible. Dashes are incompatible. The wiring is incompatible. Basically if your building a race truck with no electronics or electronic engine controls and a carburated engine, it'll work.
The fenders will work, as will the bed.
You need a 95+ cab. 93 and 94 are too much like the 89-92.
bc everythings lookin the same to me ive looked at the dashes an they look like they will swap also. and im tearin out all wiring harness from the 93 cab an putting the wireing harness out of the 99 in it with the dash
Quick question... Where are you gunna mount the ecu? 93 is in the lower DS of the fire wall, 99 is mounted top center of the firewall. That's just one of the many differences.
For
