Just thought of this, never tried it before, but it may be worth shot. Take a brass drift, knock all your studs out, and then, *CAREFULLY* and while leaving the jack under the axle let her down. There is a good chance you will damage the rim, but you probably already did that when you barbecued her. There is an equally good chance that you drop your truck if you don't do it right. might want to set a stand under the axle just shorter than the axle height with all 4 wheels on the ground.
I would just like to emphasize that, as this is my idea, and its an extreme situation, it is also a *VERY VERY VERY* bad idea. I would really only do this if litterally all else, an axle swap and my afore mentioned dynamite included, fails to resolve your issue.
