Right rear turn signal stopped working
Ted R.
10/2014 MTOTM Winner
MTOTM Winner
Oregon
I noticed this problem last weekend and have replaced the bulb, but that didn't solve the issue. The other 3 signals work properly. The signal lights on the dash blink and click normally and at the same speed. It's just the right rear light that failed.
Since it is just one, I didn't bother to look for a blown fuse, and since everything looks and sounds right inside the truck when I toggle the signal switch, it doesn't sound like it needs a new flasher (based on the little information I've read).
Any ideas?:icon_confused:
on a more serious note, check for power and ground at that socket. im guessing youve got a broken wire or corrosion or something, since everything else works the way it should.
