rogerranger2122
- Jul 20, 2016
- Automatic
This is an email I just sent to Bosch after buying my sensors an hour ago, just seeing if I can get some insight from here in the forum. thanks.
I have a question about oxygen sensors.
I have a 2000 Ford Ranger 2WD 4.0L 6 Cylinder XLT Pickup.
I plug that into Advance Auto Parts website to find the matching O2 sensors.
I need Left and Right Upstream sensors.
I purchased what said to Be the Right Upstream and Left upstream. I bought these exact ones
Part No. 15716 For the LEFT
http://shop.advanceautoparts.com/p/...sor-15716/5730003-P?searchTerm=oxygen+sensors
Part No. 15718 For the RIGHT
http://shop.advanceautoparts.com/p/...730005-P?searchTerm=oxygen+sensors#fragment-2
So as I'm picking up my order I pre paid online for, I checked the contents to see if anti seize was already included on the threads by Bosch (which it was thanks).
But I noticed the wire length of both 15716 and 15718 were the same. But advance auto Parts website states in the links that
the 15718 is
Length (Sealing Surface To End Of Connector): 18.9 inches
And the 15716 is
Length (Sealing Surface To End Of Connector): 10.6 in
Both of the wires are 10.6". Which, although a bit alarming since the description stated 18.9 inches, is fine with me because the cables on my existing original O2 sensors are 10.6".
However when checking this, I accidentally mixed up which sensor was in which box. And I checked the model numbers stamped into the actual item but they are both the same thing. They both say
0258005716
but ones says
0258005716
618231
and the other says
0258005716
2092433
The boxes are different, one says 15718 and the other says 15716 (but I mixed them up and don't know which is which although alarming is that both have stamped into them 025800 5716.
I asked the guy at the store to check another box of either of these so I can know which is which based on the stamped numbers on the actual item but I bought the last one of each. I asked to just refund the order and I would buy from another Advance auto Parts but he said it was saying it can't be returned.
So my questions to you are, which of these is Right and which is Left? I know sometimes it might not even matter (as long as they're both upstream sensors, or downstream sensors), but I don't want to chance it (and replacing these is a nightmare in a tiny space on this engine). If they were universal, then I doubt all the major parts sites specify differnt parts for each Left and Right.
also, can you tell me Right and Left, which is Passenger side and which is Driver side?
Thanks
the 15718 is
And the 15716 is
0258005716
but ones says
0258005716
618231
and the other says
0258005716
2092433
Thanks
