Rico's chopped II
Yep. We're trying to make RBV history. The hardest part will be making an adapter plate to accept the TB. Stay tuned!
found this on ebay. gonna get it and see if we can use it upside down. it's an adapter to mount a holley 2barrel carb onto a tbi chevy. if it works we wont have to get one made.
Rico's chopped II
I think we're gonna fiddle with it this weekend.
New progress pics.
Here's the TBI sitting on the intake manifold.
Rico's chopped II
Rico's chopped II
The chevy gasket on top of the intake showing the difference in the ports.
Rico's chopped II
This bad-boy upside-down will connect the two.
Rico's chopped II
Side-by-side comparison of the butterflies.
Ford- 1 1/2"
Rico's chopped II
Chevy- 1 3/8"
Rico's chopped II
Just for fun!
Rico's chopped II
Also made some headway on wittling down the harness. (no pics)
Dangerranger83 tried swapping, I believe, a 3.8 TBI onto their 2.8... He had some mixed results. I think swaps like this are cool, and I hope for your success! Some day I will step through the door of a bronco 2 again....
the 3.8 tbi uses 2 33lb/hr injectors totaling 66lb/hr fuel delivery and the 2.9 computer (which the swap in the B2.org tech library uses) has fuel curves/pulse width setup for 6 injectors which at their operating pressure flow 14.5lb/hr each totaling 88lb/hr........not even in the ballpark.
The iac motor needs to be jury rigged.
The ford efi won't run with my duraspark distributor.
I would need to swap 2 whole harnesses dragging wires all through my cab (this will add in with just a few wires.
This setup will run at such low pressures that an inexpensive inline carb pump will work.
And my favorite part, not only will it run with any distributor, with my duraspark I can utilize the electronic spark control and so the ecm will modulate ignition curves to match rpm/fuel curves.
Of course this is all conjecture, as far as an internet search can yield, nobody has ever put a gm 2.8 tbi onto an rbv, much less utilized the electronic spark control.....we are breaking some new ground here.
relax. i'm not putting any chevy emblems on my truck. just goofing around.
I ordered the adapter yesterday. look for updates by middle of next week!
Here is this weekend's progress.
My adapter came saturday and we discovered that the threads were different. a tap and some helicoil solved that.
Rico's chopped II
Rico's chopped II
Chevy TBI studs in.
Rico's chopped II
The Chevy thottle "nub" was not compatible with my B2's throttle cable so we had to swap the ford nub on to the throttle body.
Rico's chopped II
The Chevy nub was rivetted on so a grinding got the job done.
Rico's chopped II
Rico's chopped II
Ford nub on the throttle body.
Rico's chopped II
Here it is mounted to the B2 2.8.
Rico's chopped II
Also scored a fuel pump of a fuel injected F150 from the junk yard.
Rico's chopped II
Cammeddrz and I made some more progress yesterday.
One of the valleys hung over the adapter about 1/8" so we used some Kwik-steel to fill the gap.
Rico's chopped II
Making some progress on the harness.
Rico's chopped II
Here is roughly how much of the Chevy harness we need. (there's probably some more stuff that can be cut out though)
Rico's chopped II
The harness in the BII. (the computer will be mounted in the stock BII location on the passenger kick panel)
Rico's chopped II
We found that the coolant temp sensor threads in perfectly.
Rico's chopped II
Rico's chopped II
Thats all for now. Need to go get some fuel line and some wire loom now and work on where to mount some of the stuff like the fuel pump, relays, and the ignition coil. More updates soon.
