Review of a PowerTrax 1820-LR in a 2011 Daily Driver
Rear tires post-locker.
I see what the problem was now, you were using chinese tires from 1973...
Call it what you will, I simply do not believe Tom Hanks should be allowed to sell spaghetti at the post office.
wow, looks like you were doing burnouts or figure 8’s with a full spool.
Just an update, and because I read forums too and part numbers help.
Removed the locker and installed a factory limited slip carrier, and rebuilt with ford part # 6L1Z-4947-B, oem clutch set mustang1999-2014
Stacked factory style, 1994 ranger carrier and s spring, royal purple fluid, no additive, clutches soaked 1/2 hour.
Truck drives like a dream now. Smooth, positive bite when I need or want it, no jerking. Truck rides and drives beautifully.
A lunchbox locker on asphalt is f*cking horrible. IDGAF what anyone tells you, don't do it. It f*cking eats your tires and sucks to drive. Oh, and it ate two more tires before it left. A**hole locker...
i will NEVER repeat this mistake.
That said, I have a powertrax 1820-LR for sale, 6000 miles on it.
How much? I think it would fit my pinto. I returned the one I bought for the ranger.
Pm me, you'll save me an ebay listing.
Locker fits 8.8, 28 spline, open carrier.
I have the donor axle here if any of you need stuff. Its a rebuild, and was the same price as just the carrier so I snagged the whole thing. Shafts are new, has sway bar, 3.73 open, new ring and pinion, plastic cover.
Ahhh crap nevermind I thought you had a 7.5. I'm not going through the hassle of putting an 8.8 in a damn pinto.
That tire wear is indicative of a bent rear axle housing (tires more worn on the insides). Not saying the locker didn't accelerate the wear (it does to some extent), but I think yours is a combination of issues.
