RobinHood
To replace the bushings on the frame side of the radius arm, do l have to remove it completely from the truck,
.... or can l drop the bolted in superlift brackets and replace it?
l assume the reason the manual says to completely remove it is because the stock carrier is riveted in. But with it being bolted in, it would be a lot easier to drop the bracket and replace it? Any thoughts?
l just want to make sure if l drop the bracket, l will be able to line everything back up...
