REPLACEMENT LUGNUTS
"Risky Bizness"
Humboldt, Ks
255/65R18
"NOBODY tells a story where they look BAD"
Am going to replace the lug-nuts on my wife's 2024 FX4 Lariat Ranger. I'm assuming they are the "junk" 2 piece nuts.
IF you've replaced yours, what did you buy and where did you get them? Name and model number would be appreciated.
Thanx,
"Risky Bizness"
I've come to hate the original two-piece lugnuts.
The local tire shop that I use has good, one piece replacement lugnuts, and he doesn't charge me an arm and a leg for them, since I've bought tires from him for years.
It may be worth a shot, to check with some local shops.
Thanx,
"Risky Bizness"
I bought these. So far, they have held up to the salt and brine PA likes to throw on their roads in the winter.
I just destroyed some 2 piece nuts on my Edge. different threads than Rangers
it seems I used the worst tool possible, a 12 point non-flank drive socket.
totally chewed up the cladding, specifically it rounded those 6 points right off.
the impact wrench really sped up the process :icon_rofl:
use only a 6 point flank-drive socket, they won't round the cladding off.
FYI, removing the cladding on those 14 x 1.5 21mm EDGE nuts reveals a 25/32" bare nut. 20mm is slightly larger and will work.
EDIT: your Ranger should take 12 x 1.5 nuts, different than Edges
EDIT: I obtained used take-off nuts from my local Ford dealer. new ones are kinda 'spensive
I got McGards. Partly because the OE two-piece units are shit, partly because I wanted black.
Make sure you get lugs with a 60 degree shoulder to fit the factory wheels properly.
Jeg's has the best price, Amazon has them too.
Go to McGard's website to get the proper part numbers, then order from Jeg's or Amazon.
get those lugnuts and a bumper sticker that says you just got passed by a woman.
