Cheeko
- May 16, 2020
- Texas
- 4.0 V6
- Total Lift
- 2
HELP!
First I'd like to at least claim to have searched the entire world wide web to find the answer to my current problem.
I replaced the head gaskets, lower air plenum gasket, push rods, rocker arms, valve cover gasket, header gaskets, and for break in threw some 0W-20 and a new oil filter (as recommended on a forum somewhere) on my 99 4.0 OHV Ranger. Used a torque wrench to verify proper assembly and whatnot, and followed instructions on this forum (probably). I inspected the lifters and they all seemed fine - no wear on the bearings and free of obvious wear and tear. Considering what Ive seen after changing the oil pan and cleaning the parts removed on this job, I have no reason to think that the engine has been neglected aside from 1/4 inch of blue RTV on everything from a previous head gasket change.
The problem is that the truck now idles very rough and is substantially worse as far as noise goes (and was no better when it had factory recommended oil in it). Used the mechanics stethoscope and the noise is most prevalent from the drivers side valve covers.
I soaked the parts in regular old oil for an hour (maybe two), and have run the engine long enough to burp the cooling system (~10 minutes)
My question is: The noise is loud enough to prompt me to pull everything back apart to verify proper installation, but I'm aware there is a break in period for these new parts. How loud is too loud? I could post a video if it would help.
