barrys
I put on some Bosch ICON wipers which cost freakin 40.00 for the pair. They started streaking pretty fast and I didn't feel like replacing them.
Note: although most assert the ICONs can't be refilled, in fact they can. See this post:
http://www.passatworld.com/forums/showthread.php?t=127303
Get the refills from the VW parts counter for like 10.00 for the pair and cut to fit.
A great online source for wholesale VW parts from the dealer is:
http://www.vwpartsdepartment.com/partlocator/index.cfm?siteid=215190
They are my local VW shop and their internet prices are the lowest I could find. The parts techs named Chris and John are amazing.
Doing the refill on those is doable -- I've done it -- but it's a PITA and it's easy to break the little clips on the ends.
Even with that, I was too cheap and lazy to even do the refills. So I googled around and added my own little additions and came up with something that worked and should work for any blades.
1. Get a kitchen grade ScotchBrite pad and soak it with some isopropyl alcohol.
2. Wipe down the squeegee a few times and then wipe repeatedly with clean paper towel until the paper towel is clean.
3. Repeat step 2. that 2 or three times.
4. Spray the wiper blade with some silicon spray and let it sit for 10 mintues or so.
5. Wipe it down again, repeatedly until it's clean.
6. Soak a paper towel with alcohol and wipe down the squeegee.
7. Follow up with a clean paper towel until clean.
Sounds like a lot, but it was like 5 - 10 minutes of real work.
Good as new -- no kidding. Streak free when running the windshield washer.
Put the 40.00 in the kitty for your next tune-up...
I'm interested on getting some feedback on this...
One thing I thought about was to not do anything after applying the silicon spray since people rave about the the PIAA silicon coated wipers. But, I thought I'd have an oil and water problem smearing the silicon on the windshield.
Another thing people said on other forums is that the alcohol will dry out the rubber. But, I can't see that being an issue relative to the rubber sitting out in the weather. And, the cleaning with alcohol seems to be universally accepted method for cleaning.
Let's see what others think...
Whadaya think???
Whadaya think???
